Fueling & Injection - Racetronix/Hotwire Fuel Pressure fluctuates with nitrous
BadAssFast
02-11-2006, 02:42 PM
I have a properly and well installed new Racetronix fuel pump and the hot wire kit. Everything installed to exact spec. When I drive the car I have excellent fuel pressure 63-4 psi. My elctronics Autometer sender is at the test port on the fuel rail...when I nail my nitrous my fuel pressure fluctuates as much as 20 psi. How can I test the fuel pump to eliminate it as the problem?
WS6FirebirdTA00
02-19-2006, 12:59 PM
what size injectors do you have? and what kinda power are you making?
BadAssFast
02-19-2006, 01:31 PM
This info is very specific in the link in my sig (http://sig.macon-moore-performance.com) (http://sig.macon-moore-performance.com) but generally the numbers 430 RWHP NA at 585 RWHP w/ 150 wet. Keep in mind 4L60E and SS3600 Stall with 4.11 rear. Racetronix (Lucas) 42 lb injectors.
WS6FirebirdTA00
02-19-2006, 01:47 PM
reason i asked is i was wondering if you were maxing out the injectors and it was causing this drop, either that or maxing out the pump? im not sure the limits onthe pump though
Racetronix
02-20-2006, 12:19 AM
Without a FM FPR installed pressure fluctuations in the range of 52-62PSI are not uncommon. This is a shortcoming of the factory system.
BadAssFast
02-20-2006, 07:30 AM
FM FPR I don't want to assume anything please decipher this acronym.
Matt@HSW
02-20-2006, 07:32 AM
I'll take a stab at it: Front Mounted Fuel Pressure Regulator.
Matt
BadAssFast
02-20-2006, 10:29 AM
Matt
I'll bet you are right there Matt...it has been suggested to me by a couple of folks here (possibly you included) that a replumbed system including a fuel pressure regulator mounted up front and return would be a solution. Again thank you Matt. I think I have a solution that I will try. I will get back with the results.
- Macon
