Stereo & Electronics - Easiest way to remove HU?
View Full Version : Easiest way to remove HU?
5.3litre
02-12-2006, 01:54 PM
How can you get the stock HU out? i tried a couple of different things but i was afraid to snap anything. So how is it done? thanks!
VIP1
02-12-2006, 03:20 PM
Details, Details, Details.....
What car/truck/plane/boat/tank/other are we talking about?
5.3litre
02-12-2006, 05:25 PM
2001 ws6.. sorry
98boxer
02-12-2006, 08:08 PM
Pull on the trim that surrounds the radio. At the very top you will have one or two connectors connected, one/two, too ASR or Foglight button, depending which you have or if you have both. So take off the trim, becarfull not to yank the top part of the trim before disconnecting the connection/s. And that it. To put it back, connect the wires to the Asr or Foglight and push trim back in making sure the pins are lined up to the holes.
5.3litre
02-12-2006, 09:15 PM
thanks for the help but im still not quite getting it. my foglight switch is right under the dimmer swith and the asr isnt even close to the radio.
kraaazymike
02-12-2006, 10:06 PM
Hes actually talking about taking out the bezel for the camaro.
For us, we dont need to worry about any wiring. The bezel pulls straight out from the dash. Personally I start prying my way from the top right using a flathead screwdriver and work my way clockwise pulling it out straight. I stick it in between the bezel and the radio. Once you get that off theres two bolts youll need to unscrew that hold the radio into the dash itself. Voila!
5.3litre
02-13-2006, 07:35 PM
ok cool..thanks
VIP1
02-15-2006, 09:11 PM
Sorry, I'm late in responding.
Check out this thread from a while back:
http://ls1tech.com/forums/showthread.php?t=351228
I posted a video there as well.
After you pull off the bezel, there are 3 screws holding the headunit in place.
