Small Block & Big Block Chevy Specific - flat top or dished pistons?
View Full Version : flat top or dished pistons?
Eric95
02-16-2006, 05:01 PM
Im in the process of building a 350sbc and im buying a rebuild kit for it. I have the option of dished or flat top pistons. which should i go with?
Villain281H
02-16-2006, 10:03 PM
depends on heads selection and what you want to do with the engine.
I've run flat tops because with a 64-67 cc heads they'll return 9.5-10:1 compression ratio in a 350, and with aluminum heads it will work fine on pump gas naturally aspirated. If you are planning a forced induction route dished may be the piston to use.
Derek
Strokinit383
03-05-2006, 03:44 AM
Flat top pistons burn more fuel efficient. I would opt for them, especially if you can get some forged ones.
