Stereo & Electronics - Audio Question, Help...
View Full Version : Audio Question, Help...
mrcdvrs
03-15-2006, 12:05 AM
I've just replaced my stock door speakers with the Infinity Kappa 62.7. I replaced them because my driver side speaker would distort with any bass levels. I would have to turn the bass knob almost off to lose the distortion. So as mentioned I replaced both front speakers. But the problem still exists not nearly as bad, but I can't crank my sterio. I have the stock monsoon amp and the stock head unit for my 2002 Z28. Any input/ideas would be greatly appreciated. :confused:
Rage113
03-15-2006, 01:11 AM
Is it still just the drivers side speaker making the distortion? Or do both front speakers sound the same..
Rage113
03-15-2006, 01:26 AM
You're gonna need to purchase an aftermarket head unit to make those Kappas sound right anyways. I had the same problem with my front speakers, and replaced them with Boston Acoustics along with a new Eclipse cd head unit. They sound great now.
HiTechGent
03-15-2006, 01:31 AM
I like my Monsoon system with my Alpine speakers. But if you like your music loud, or are picky about sound quality, an aftermarket HU would better suit you.
TARZAN
03-15-2006, 02:09 AM
Get some bass blockers...
-Will
2MuchRiceMakesMeSick
03-15-2006, 03:06 AM
Probably the best route for you would be a 4 channel amp (with a head unit or a high/low level converter) with a built in crossover. Let all 80+hz pass. That will cut out most of your bass which those speakers are not designed for. If you need more then you can look into a stealth box or something similar.
