Stereo & Electronics - which wire is switched power for TA power antena?
badmfkr
04-11-2006, 09:14 AM
want to power up amp which color wire is switched power from the power antena ?
Thanks
firebird327tpi
04-11-2006, 09:33 AM
from the stock radio...pink
badmfkr
04-11-2006, 10:14 AM
not from the radio from the back of car at the power antena this is where I want to get swicthed power.
Thanks
Brains
04-11-2006, 10:39 AM
The middle wire in the connector.
ZeeVert
04-12-2006, 11:38 PM
This may be a stupid comment... but isn't the "power" wire to the antenna always hot? How else would the antenna go down when you shut the car off?
...so that wouldn't really be "switched" power?
SlowTA367
04-13-2006, 08:53 PM
I'm pretty sure it only goes up and down when the radio is turned on and off.
WhiteBird00
04-14-2006, 07:31 AM
The connector at the antenna has three wires - orange, pink, and black. The orange wire is constant (battery) 12V+ and the black wire is ground. The pink wire is the control wire from the radio. It is used to energize a relay in the antenna controlling the antenna motor. When the radio is on (regardless of whether it's playing a CD, tape, or the radio), 12V+ is applied to the pink wire closing the relay and putting the antenna up (or keeping it there). When the radio is turned off power is removed from the pink wire, the relay opens, and the antenna motor lowers the antenna using the power on the orange wire.
