Stereo & Electronics - Rear speaker box completed. My 1st fiberglass project.
Schantin
04-11-2006, 08:44 PM
Well, I never made a speaker box out of fiberglass before, so this was an experiment. Took a good 40 hours of labor in the end, between measuring, sanding, laying fiberglass, and painting.
One thing I noticed is that it is not as efficient as the wooden box I had previously. I can jump up and down on this fiberglass one (it's strong), but it still resonates a little and it does not produce as low of bass as the 3/4" MDF box did. Guess nothing beats MDF for low-end thump. :bang: Oh well, I spent far too much time on this to not run with it!
The up side is it looks a lot better than the wooden box did and it's still loud. :) Let me know what you think. I'm happy with it. :)
http://img63.imageshack.us/img63/3315/fiberglasssubbox30ve.jpg
http://img137.imageshack.us/img137/2257/fiberglasssubbox25yh.jpg
http://img137.imageshack.us/img137/9264/fiberglasssubbox11dt.jpg
SailorZ28
04-11-2006, 09:25 PM
That looks real clean! I like it a lot!
imnotplutonium
04-11-2006, 09:32 PM
wow that looks great!
Phoenix 5.7
04-11-2006, 09:43 PM
Looks good, very good fiberglass work, but the white looks out of place in a gray interior.
Schantin
04-11-2006, 10:12 PM
Thanks for the compliments. :) I picked white because the exterior is white. So's the Hurst shift knob. Ties the outside color into the inside. At least that was the idea.
ultraz
04-12-2006, 06:02 PM
great work, but shittty sub..... you should start making boxes for people who need a 12" box
crazymofo1986
04-12-2006, 06:41 PM
unless u couldnt with that spot. you should have made a box out of mdf and fiberglassed over it and around it
Josh_101
04-12-2006, 06:59 PM
Looks like the grill is just about on top of the surround.
ultraz
04-12-2006, 10:04 PM
just curious, how did u get the face to look that way, is it competely fiberglass?....... because I just used a 1" MDF as the faceplate portion and the rest was fibergalss. You should make a write up on how u did it for the do it yourselfers, great work honestly
j99fbody
04-12-2006, 10:07 PM
looks good
Schantin
04-13-2006, 01:53 AM
If I do another, that's exactly what I'll do. I think the bass would be tighter. I origonally went with pure fiberglass thinking I could get a bigger volume (the current box extends through part of the rear panel.) and thus a deeper bass. In retrospect, nice dense 3/4" MDF is a better choice, even though the volume is about 1/2.
To answer other questions, the front is 100% fiberglass laid over stretched felt and smoothed with bondo. The sub is $hit....but works suprisingly well with the inclosure :jest: Also, the speaker grill comes darn close to touching the surround. Doesn't vibrate though.
Thanks again for the compliments :)
nhra-trans-am
04-13-2006, 04:13 AM
very professional looking. Good job.
AncientRgn
04-13-2006, 08:40 AM
I'm sooo jealous......
FireSilverLullaby
04-13-2006, 10:09 AM
Where some good places to get the materials like resin and fiberglass chop mat from? I went to lows and no one was very helpful.
Very nice box by the way!
Camarokidd24
04-14-2006, 12:22 AM
currently gathering stuff to build my own box just like that for a 12" W6v2.
how about a nice write-up for some fellow f-body peeps (myself included of course)?
do you know how much volume you got out of that with the extention?
DAVESS02
04-14-2006, 01:59 AM
Very nice!! Good job!! I made one out of plywood. A million seams and not anywhere near as nice looking as yours.
Schantin
04-15-2006, 05:48 AM
Thanks again for the compliments. :) I got Bondo fiberglass resin and fiberglass mat from Wal-Marlt of all places. Ditto for the felt material and the Bondo filler material. I will have to work on a write-up. I pretty much did it like the sticky that's at the top of the stereo section here on "how to fiberglass". I will measure and post the dimensions for the front template. Just give me a day or so.....
2MuchRiceMakesMeSick
04-15-2006, 11:59 AM
You might try coating the inside of the box with some spray in dynamat for better wave suppression.
For a first time you did an oustanding job :cheers:
Although I personally would have matched the box to the interior.
