Stereo & Electronics - where to put sub w/ cd-changer
View Full Version : where to put sub w/ cd-changer
Air
05-11-2006, 08:34 PM
I have a stock system all around (as far as i know).. monsoon, 98 t/a.. and i have the tape deck in the head-unit and the trunk mounted cd-changer which is over on the left where most people usually mount their subs..
Does anyone make a sub box to go on the right side (where the spare was...)
Blacker
05-11-2006, 09:47 PM
Of course:) Subthump makes a passenger side stealth box. I am using it and fits great. You will have to loose the spare tire and cut the trim panel.
02trns_am
05-11-2006, 11:59 PM
You can do what blacker suggested or you can get the box for the drivers side (where the factory cd changer is) and also get an amp rack from subthump and put your amp and cd changer on that it looks good.
jrnorman
05-12-2006, 08:04 PM
I made a box that fits in front of the spare tire. It is big enough for most 10" subs and put the sub amp over the CD changer. I can still put my Tee-tops in the boot and get to the spare tire with a Phillips screwdriver and a deep 10 mm socket. I can send pics if you want by email but I am not astute enough to insert them in a reply. <computer illiterate, I guess>
Air
05-14-2006, 03:48 PM
ok thanks guys i guess im gonna look @ what others did for a pass side sub box and see if i can fab my own in that style
Blacker
05-14-2006, 06:34 PM
I just updated my sig and it might give you a few ideas.
