Stereo & Electronics - need help installing air/fuel gauge
kyles2000z
05-15-2006, 11:17 AM
anone have a good write-up of how to install an air/fuel gauge? its the autometer cobalt series if that matters.
kyles2000z
05-15-2006, 11:50 PM
anybody chime in here??
kyles2000z
05-16-2006, 10:42 PM
25 views and no one knows?
theinstag8r
05-17-2006, 11:09 PM
the instructions are really accurate and easy to follow. # 46 pin on your pcm should be solid purple for the 02 sensor.. i ran a wire through the grommet in the firewall on the passenger side then spliced it in..... find a good solid ground where ever your mounting it and a switched power source
bigti99a
05-19-2006, 05:31 PM
i just ordered the o2 sensor pig tail, wired it up that way adn ran it to the a pillar through the hole for the shifter in the center consol.
kyles2000z
05-21-2006, 11:25 PM
is it #46 on the top or bottom connector? im assuming the bottom one?
kyles2000z
05-22-2006, 07:08 PM
anybody know i'm in a hurry
kyles2000z
05-22-2006, 07:30 PM
aight neither 46 pin is solid purple. the one on the botto connector is brown w/ white stripe and the one on the top connector is solid grey. i tapped into both of them and neither one gave me a reading on the gauge....is it in another pin on the 2000 models?
imnotplutonium
05-22-2006, 08:32 PM
just run it to the o2 sensor itself, that is what i did. splice into the purple wire on the o2 sensor. that easy
theinstag8r
05-22-2006, 08:33 PM
just looked it up,pin 65 or 66 on the blue connector for a 2000 heres the link to the pcm pins
http://www.ls2.com/boggs/torques/00pinpcm.htm
kyles2000z
05-22-2006, 09:18 PM
thanks, that was buggin the hell outta me tryin to figure it out and find a diagram.
