Small Block & Big Block Chevy Specific - Its been a while
View Full Version : Its been a while
white1
05-22-2006, 12:35 PM
Its been a while since Ive messed with Carbs. This weekend Im dropping a 92 model SBC in my stepdads 86 PU. Were going with a carb set up on it. His 69 Camaro has a 330 hp crate engine (ZZ4??) and has a small Edelbrock carb on it. I plan on swapping the Edelbrock to the truck, and hes getting a Holley 700 for the car. Im sure the Edelbrock wont be much to adjust for the truck, but I'm a little rusty on carbs anyway.
What I need to know is what kind of jetting to start with on the Holley. Were at sea level, in south La. From what I remember, the Holleys arent exactly an "out of the box" carb, but I may be mistaken. Any help is appreciated, thanks.
Strokinit383
05-22-2006, 06:36 PM
Do you know what the part number on the carb is? If so...
http://www.holley.com/TechService/Instructions.asp
Find it there. That should help out on the basics. If you have any in depth questions after that im sure there are plenty of carb gurus on here that will help you out. Im knew to carbs myself and and beginning to conquer this speed demon. Gook luck with the swap.
