Small Block & Big Block Chevy Specific - sbc in 94 v6
View Full Version : sbc in 94 v6
Eric95
05-23-2006, 07:24 PM
I tried a search but i couldn't find what i was looking for. Im about to start a project of dropping a 355 sbc into a 94 V6 camaro. Do they make conversion motor mounts for this swap and where can you get them? Also can I use the stock 5 speed? I would really like to keep the car manual.
ROCNDAV
05-23-2006, 08:03 PM
I would think that it would be easier than dropping in an LS1. Doesn't most of the LT1 stuff line up with SBC? Why not drop in an LT1?
TimTaylor75
05-23-2006, 08:18 PM
From this (http://ls1tech.com/forums/showthread.php?t=490284) thread.
Here is a little list that I've put together for myself and you can search and find many more threads with useful information to help with your swap as well.
http://ls1tech.com/forums/showthread.php?t=398775 – swap info
http://ls1tech.com/forums/showthread.php?t=269010 – swap info
http://ls1tech.com/forums/showthread.php?t=354351 - How To Remove the Engine From the Bottom
http://community.webshots.com/user/badss97 - swap pics
http://www.michiganspeed.com/enginepull/index.html - engine removal
Eric95
05-24-2006, 08:37 PM
i dont really want to use a motor plate, so does anyone know for sure about conversion motor mounts?
Camaro396
05-26-2006, 07:38 AM
You can find swap crossmemembers and trans mounts on BMRs website. Get your wallet out and make sure its thick :)
cwaldt
05-26-2006, 03:18 PM
You can make a stock K-member to work for a SBC/BBC. Just looks for links to my post under my screen name. Your job should be a little bit easier than my BBC install but most of the process will be the same.
Strokinit383
05-26-2006, 11:09 PM
Many people dont know this, but you can use 5 out of the 6 bolts from lt1 motor mounts. Im going to try and figure something out for the 6th this summer so that i can have a back up if this tubular k member cracks, as many people claim theirs have. The 6th bolt is behind the driver side rubber mount on the bracket. On the lt1, they had a seperate bolt hole and the mount is extended backword to accomodate for the hole lost underneath the rubber mount. All the passenger side bolts work fine.
