Small Block & Big Block Chevy Specific - Fresh 396 making a slight ticking noise???
Chevy396SS
05-27-2006, 02:08 PM
I just installed a 396 that I built in my nova. It runs great other than there is a ticking noise that seems like its coming fom the front of the motor. But you can only hear it at idle and just above idle. Im not too sure what it could be. Ive checked the valvetrain and set the valves correctly. If anybody has any thoughts id sure appreciate it. Here are the specs in case you are wondering. 396 60 over. cast crank, trw forged pistons. comp 232s grind. comp stainless roller rockers. howards pushrods. Closed chamber 101cc heads 2.02 1.19 valves.
NWDragRacer
05-27-2006, 02:15 PM
Does it have a new fuel pump? Sometimes a broken spring in the fuel pump will make the pushrod float and tap back int the cam lobe.
Strokinit383
05-27-2006, 05:46 PM
Are you running solid or hydraulic lifters?
Chevy396SS
05-28-2006, 04:18 AM
solid lifters. The fuel pump is new but its some off brand and didnt seem too high quality. Ill check it out thanks.
Strokinit383
05-28-2006, 08:58 AM
Solid lifters usually take quite of bit of finess to get them perfect, then they will always need adjustments now and then to keep them correct. They will tick if they arent adjusted exactly perfect. I would go through and recheck those first.
Chevy396SS
05-29-2006, 01:46 AM
Found out what it was. It was the timing chain nicking the bottom of the timing cover, what a joke.
Tiresmokin
06-01-2006, 06:01 PM
I had a similar prob with my Chevelle and a 396 I built. Made a rubbing/ticking noise under the timing chain cover. Eventually went away and didn't rub through.......
