Stereo & Electronics - New to site have a question
View Full Version : New to site have a question
99beaSSt
06-13-2006, 10:25 PM
I have a 99 camaro SS. it has the monson sterio in it, my question is : ateri put the after market cd player in the factory amps quit, how come they quit and how can i use them with the aftermarket cd player? Thanks for all the help. :bang:
spy2520
06-13-2006, 11:11 PM
i dont think it is worth using the factory amp with an aftermarket cd player especially if you replace the speakers. but i figure if you didnt bypass it with wiring, it is kinda sorta still working because the speakers with an impedance other than 4 arent playing any different are they?
99beaSSt
06-13-2006, 11:20 PM
i dont know if the amp runs the two in the back seat or all 4, but as far as i can tell they all seem the same in loudness. Im just not getting enough bass out of the back two. sould i take it to a car audio place and see what they say(trying to save some money im "f"ing broke lol)
WhiteBird00
06-14-2006, 08:23 AM
If they are all the same volume then the amp is working - there would be nothing coming out of the sail panel speakers (beside the back seat) if the amp wasn't working.
99beaSSt
06-15-2006, 12:03 AM
Ok, i understand, but why does the bose sterio system sound better in my 94 camaro? Should i have more bass comming from the back two? How can i check the amp to see if it has power to it too? Thanks
WhiteBird00
06-15-2006, 08:12 AM
Well, the Bose system had a true sub in the back unlike the Monsoon's two mid-bass speakers in the sail panels that GM calls "subs". Also, the Bose system used special high-impedance, low-level output head units while the Monsoon uses an ordinary Delco radio for the head unit (speaker-level output with the usual factory distortion level).
You can check for power on both of the orange wires (next to each other in E11 and E12 of the blue connector) at the amp. If there's no power then check your RADIO ACCY fuse in the fuse panel at the side of the dash.
99beaSSt
06-15-2006, 11:53 PM
Thanks for this info ill try it and ket you know thanks again for all your help.
