Small Block & Big Block Chevy Specific - BBC manifolds for twin turbos?
LS69TA
06-15-2006, 05:31 PM
Anybody know of a company that sells exhaust manifolds, etc. for the BBC's for a twin turbo setup? I'm thinking about replacing the 460 in the boat and putting a TT 454ish motor in it. If all else fails, I may just put twins on the 460.
Project GatTagO
06-16-2006, 07:21 PM
Noone that I am aware of. I have looked.
Andrew
TwoFast4Lv
06-17-2006, 02:49 PM
Check With Jose in the FI area. THey make some nice SBC units for less then half the price of the banks ;)
LS69TA
07-03-2006, 03:40 PM
Well we decided that we can make our own flanges. Anybody have a link to where I can get tubing to make them out of?
This is going in a boat!?
LS69TA
07-03-2006, 05:53 PM
Yep :devil:
LS69TA
07-03-2006, 05:56 PM
We figure we can run some stupid boost because of the water/air intercoolers. The water at ~70 degrees should chill the air plenty, enough to run 20-25lbs of boost. We're figuring in the ballpark of 1500hp.
If things work out and there is a market for them, we'll start producing the exhaust manifolds and modified tunnel rams with internal intercoolers.
dacajun
07-04-2006, 12:43 AM
The marine manifolds you are wanting to build will need to be water cooled, are you aware of that? Also with 20-25lbs of boost you better have a stong rotating assy. and a very good engine management. It can be done...
-Dave
BLWN1
07-04-2006, 01:01 AM
wonder if Joses will work in a 95 camaro with a SBC...
Side note, do you have space constraints? if not there is a guy on turbomustangs.com that could do it.. I will have to find his name if interested...
LS69TA
07-04-2006, 11:04 AM
-Dave
The exhaust manifolds will be just like any other, with thick gauge tubing. They'll be air cooled, not water cooled like the headers I currently have in the boat. The intercooler will receive regulated water straight from the jet drive pump so it's as cool as possible. A forged rotating assembly will be used, however we'll be keeping the rpms down because the boat won't be used for much top-end runs. As of now we're going to use the Megasquirt system for fuel management. It's cheap and can control up to 16 injectors as needed.
LS69TA
07-04-2006, 11:15 AM
No space constraints here. This is an identical boat to mine:
http://newimages.yachtworld.com/1/5/5/6/9/1556947_2.jpg
Turbo_Nova
07-04-2006, 02:55 PM
That was a budget build for the guy. Twins would have cost more
LS69TA
07-05-2006, 10:04 AM
I think I have a hookup on some turbos, so that will help with the cost. How well did his run without intercooling?
Turbo_Nova
07-13-2006, 07:10 PM
95 mph on 5 psi and pump gas. At 10psi it is almost undrivable. 632hp on 93 octane on a very conservative dyno. It is a V-drive.
