01BlackCamaroSS
06-17-2006, 05:34 PM
I just purchased a 91 z28 all it neeeds is a new motor in it, i was gonna go ahead and pull the tpi motor out and junk seeing as how the guy who owned it before me spun a bearing in the bottom end. I was looking into purchasing either a rebuilt 350 or 383. If i did this would the motor be able to drop in and hook up to the 700r4 trans thats in the car already, and then run? will i have to worry about any of the emissions stuff in order for the car to turn over?
NemeSS
06-17-2006, 08:19 PM
it depends on what ur goals are with the car
if ur gonna go nuts then forget about emissions
any sbc engine will bolt back up to the 700r4
01BlackCamaroSS
06-17-2006, 11:21 PM
i plan on making it a street and strip car will the tpi setup from the old motor bolt on to a 350 or say a 383 and run?
383LT1S10
06-18-2006, 06:14 PM
I'd reconsider using the TPI setup if you are going to a 383. They are not very ideal for high cube engines requiring lots of air and they fall on their face pretty early on the tach. I say 383 with an aftermarket manifold.
