cwaldt
07-02-2006, 03:03 PM
Here are some photos of my setup. I hooked up everything to get a test run on the motor in the car. The fuel pump isn't what I'm using I just used it on the test run.
For those wondering about if you can take the dist. out with the motor in the answer is yes, you just need to cut the cowl all the way back to the firewall like I did. I take the cap off and the pull the dist. up and take it right out.
The only clearance issus I have right now is my wiper arm and my carb. But that has alot to do with my intake. My choses are to move the motor forward 1", go to a different intake or just have a drivers side wiper. I'm going to try moving the motor forward first. I've got to pull the motor so I can clean and repaint it so I'm going to try and modify the K-member some.
http://www.porteighty.biz/uploads/lview454.jpg
http://www.porteighty.biz/uploads/fview454.jpg
http://www.porteighty.biz/uploads/fview454_2.jpg
Here is where I was without the carb and before I cut on the cowl.
http://www.porteighty.biz/uploads/incar4.jpg
