Stereo & Electronics - power window harness question
View Full Version : power window harness question
408Maro
07-08-2006, 09:04 PM
my 02 z28 currently has manuel windows and door locks and all that if i got the whole door off a 98 z28 is there a harness some where in there or what can i do?
WhiteBird00
07-09-2006, 02:12 PM
There's a lot more involved than just the parts in the door. Yes, you'll need the door parts (harness, switches, window motor, lock solenoid) but you also need a different BCM containing the keyless entry option, a window control module that mounts under the dash, and the wiring for them.
408Maro
07-10-2006, 09:44 PM
wheres the window control module at? the bcm seems easy how bout that though
WhiteBird00
07-11-2006, 08:01 AM
The power window module is a small black box mounted in a pocket attached to the dash mat under the dash behind the center console close to the transmission tunnel.
http://www.fl1v.org/ls1/powerwindowmodule.jpg
408Maro
07-11-2006, 10:25 AM
thanks alot i appreciate it
