Small Block & Big Block Chevy Specific - How am I Looking on HP numbers!!! Any guesses?
2005suburban
07-13-2006, 05:49 PM
New Chevy 350 block - Bored. .030 - 4.030 Stroke = 383 Stroker
Eagle Crank
SpeedPro Pistons
Eagle S.I.R Rods
Federal Mogul Plasmamoly rings
Dart Iron Heads- 2.02intake/1.60exhaust 165cc Runners- 67cc Combustions C
Comp Magnum 270h - specs. 224-224-470-470-110
Weiand X-CELerator Intake Manifold
Holley 750cfm Double Pumper Carb
High Performance Oil Pump
Ceramic Coated Long Tube Headers
K&N Air Breather
7-quart Oil Pan
Windage Tray
Holley Blue Electric Fuel Pump
Short Neck Waterpump
Electric Fans
And behind this motor a TCI TH-400 with a 3000 Stall Lock-up
rhamm1320
07-13-2006, 09:29 PM
Here the dyno simulation http://www.virtualengine2000.com. The compression ratio worked out a little higher than I thought (just over 10.5:1). Do you run a dished piston instead or is that about right?
http://www.hotrodink.com/Images/data/546/12005suburban1.jpg
http://www.hotrodink.com/Images/data/546/12005suburban2.jpg
2005suburban
07-14-2006, 12:04 AM
Yeah.. Its actually a -12cc dished piston!!
2005suburban
07-14-2006, 12:05 AM
and were going to spin it to around 6000-6100
GOaT Cheese
07-23-2006, 04:07 PM
With a rod to stroke ratio of 1.52, I don't think you are going to like that single plane intake. That is assuming your are running a 5.7 rod.
