Stereo & Electronics - Mounting factory CD changer question ?
2000blkta
08-03-2006, 08:59 PM
Are the brackets available to mount a Delco CD changer in a car that originally was not built with one ? Is all of the cabling there to plug it in ? I get my 2000 Trans AM tomorrow but have the CD changer now minus the floor bracket - thanks!
WhiteBird00
08-04-2006, 07:53 AM
The wiring harness is installed from the factory even if you don't get the CD changer option. You'll find the end of it taped to the speaker harness under the left rear hatch speakers. The front end is already plugged into the head unit so all you have to do is plug in the other end to the changer.
However, the factory brackets were welded to the floor pan only in cars that had the changer from the factory. The easiest way to mount the changer is to slip a piece of plywood under the carpet in the cubbyhole at the back and then screw the brackets through the carpet into the wood. The combination of the carpet and the wood will keep the changer from moving.
MY02REDWS6TA
08-05-2006, 11:04 PM
I am doing the same thing with a factory changer. The unit I purchased didnt have the brackets so I went to the dealer and bought the two side ones and the one that was supposed to be welded to the floor pan. $20 total and they will be here in three days.
ZeeVert
08-08-2006, 09:10 PM
Here's a picture of what the "welded" brackets look like.
All the brackets are pretty cheap at the dealer.
I painted mine and screwed them down.
http://i2.photobucket.com/albums/y48/ZeeVert/2002%20Z28%20Convertible/050429w2bracketP1000121.jpg
MY02REDWS6TA
08-08-2006, 09:34 PM
Is there supposed to be one or two brackets like the one in your pic that is laying in front of the CD changer? Just curious??
Thanks
ZeeVert
08-08-2006, 09:44 PM
I used two. There are two mating holes or pins in each of the side brackets... So I figured two.
MY02REDWS6TA
08-08-2006, 09:52 PM
Do you think one would hold it good? When I ordered them from the dealer he told me it only showed one of those brackets. I even asked him why it had two of the mating holes and pins and of course he didnt know. So I only ordered one. I wonder if it came from the factory with one welded bracket or two?
ZeeVert
08-08-2006, 10:11 PM
Good question, but we'll need someone with a factory installed unit to tell us if stock is one bracket.
Will one work? I'm sure it'd be fine.
2000blkta
08-09-2006, 07:13 AM
Thanks for the info guys ... one question though. If I screw it down, what is directly under that "shelf" the CD changer sits on? Will the screws protrude and be visible from the underside of the car ?
ZeeVert
08-09-2006, 07:18 AM
As I recall, they do show. I used stainless screws and painted the exposed threads.
2000blkta
08-09-2006, 08:12 AM
does anyone have the part number handy for these brackets ? Andd possibly the large washer-head nuts that hold the changer down ? BTW, confirmed, one backet is used. At least on my '97 Z28 with factory installed changer.
MY02REDWS6TA
08-09-2006, 08:35 AM
Try this link from General Maintenance section. Although I took a hard copy of this to the dealer and two of the three brackets listed in the link did not match up to the part numbers that were shown/listed for my 02 TA. So I ordered what he had listed in the computer diagram.
Just FYI....
http://www.ls1tech.com/forums/showpost.php?p=3064589&postcount=2
2000blkta
08-09-2006, 05:39 PM
Thanks for the link. As for mounting I have another idea that doesn't involve drilling holes in the floor. Double sided tape to hold the bracket down. The carpet will also serve to hold the bracket in place as the bracket protrudes through two slits that need to be cut in the carpet. I'm sure this will hold more than well enough but I'd still have the option of driling and screwing BUT only if I need to.
MY02REDWS6TA
08-09-2006, 08:53 PM
Same exact idea I had....I already bought the heavy duty 3M double sided tape in 1" cut squares. I also bought adhesive Velcro strips that I may decide to use instead. Liek you, I really dont want to be drilling and putting screws in unless I have to. Good luck. My brackets should be here tomorrow.
2000blkta
08-17-2006, 08:44 AM
Update, the bracket that mounts to the floor came in and I installed the changer last night using double sided tape under the bracket. It holds strong! The carpet already has cutoputs for the bracket to extend thru so it was simple and I'm glad I didn't decide to drill!
MY02REDWS6TA
08-18-2006, 11:05 AM
I just had the time last night to mount my changer as well. I did the same thing with the double sided tape; except I had already bought the 1" squares. I cleaned the bracket and floor pan area with rubbing alcohol and I put like 10 of the squares on the bracket then carefully placed it in there under the carpet. It does seem to hold well. I will double check it periodically to make sure.
