chevygirl
08-05-2006, 02:12 PM
How do you remove the trim panel in the rear hatch area to find the cd wire to hook up a cd changer. I tried pulling but it seems to be attached somewhere. I tried sticking my hand in there to find the wire but no luck.
02NBMFormula
08-05-2006, 02:31 PM
it is attached with several push in holders for lack of a better term, simply pull up right by where you fell it is attached to the car. the push in holders are in the same place as the ones on the passenger side. the cd wire hook up is in a small piece of foam.
chevygirl
08-05-2006, 03:41 PM
I found the wire with my hands without having to remove the panel. Now the cd changer is not working. It did for a minute and then stopped.
