Stereo & Electronics - Strange doorlock issue
View Full Version : Strange doorlock issue
Chocolate Apocalypse
08-07-2006, 08:41 PM
Just recently I've been having some problems with the interior door lock switches. The driver's side wont lock or unlock, the passenger side will lock but not unlock (doesnt matter if key is in the ignition, on ACC or ON), can lock and unlock fine with the fob. I have a spare set of switches that I tried but no luck. Everything else is fine, any ideas what the issue could be? Thanks.
snketr
08-08-2006, 09:48 AM
Try the BCM?
08-08-2006, 11:27 AM
Not sure what to try. Should I get my hands on another and swap it out?
snketr
08-08-2006, 11:56 AM
Well, I've been having a problem along with another on a local board, that our radio will go off and on. At the same time this happens the windows will not work. We've discovered it was the BCM going bad. She's replaced hers and it has fixed the problem. I'm still waiting on a new BCM to get here. I think they are kinda specific on cars. I.e. needs the same options on what you currently have. So, if you can find one with the same options you have I'd try it.
