Stereo & Electronics - Car wont start (electrical reasons)
bomax
02-05-2003, 08:46 PM
I was doing some work under the dash to my clutch master cylinder and I think I bumped the wires, because now my car won't start! When I turn the key the headslights turn off, but the car doesn't even crank over. The dash lights and radio don't even flicker. It seems to me that the starter kill wire probably got disconnected (I have a DEI alarm). So I checked the yellow wire, and it is getting +12v when I turn the key. What else should I check?
Thanks
<small>[ February 05, 2003, 07:48 PM: Message edited by: bomax182 ]</small>
Chevy
02-06-2003, 01:03 AM
Check both sides of the relay. You might want to check your clutch switch harnes. <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
bomax
02-06-2003, 01:18 AM
I did check both sides of the yellow wire (before and after it goes through the alarm unit. I also already test the clutch switch..both checked out oky... <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Snootch
02-06-2003, 05:25 PM
Are you getting any "Security" lights on the dash? I had a problem like this, except the problem was due to the resistor chip in the ignition key. The reader for this in the lock went bad.
