Stereo & Electronics - Elemental Designs 11Ov.2 or 110v.4
crazymofo1986
09-06-2006, 11:45 PM
finally found a sub that i think will work in the space. i will only have one of these in a sealed box. what i need to know should i order the 110v.2 or v.4? and what amp should i match this with? thanks in advance
Empire
09-07-2006, 03:27 AM
The v.2 in 11 Ov.2 stands for version two. I assume you're asking what voicecoil configuration to buy. If you use a nine.2x to power it, which I recommend, you would need to get the subwoofer with dual 2 ohm voicecoils, so that it will have a final impedance of 4 ohms when wired to the amplifier in series. That will give it 600 watts at 12.5 volts, and it should wang mighty well. Good luck, and let us know how it turns out.
crazymofo1986
09-08-2006, 12:09 AM
ttt neone else with another amp or better idea?
