Stereo & Electronics - Weird stereo/windows problem (don't think it's the bcm)
Camaroz
09-08-2006, 12:13 PM
Alright I'm getting pissed... This has been going on for a few months now. It started with the Radio/Windows cutting out randomly. But if I gave the dash a light smack above the radio is would work again. Now last week another little goof has started. My interior lights don't come on if I open my drivers door and the Accessory power stays on like I didn't close the door. So I took apart the BCM yesterday and It looked perfect! No burn marks on the board or anything. So now I'm stumped! Anyone have any Ideas?
2001SSBOY
09-08-2006, 12:46 PM
hey man i'm having a problem two with my driver window...it will roll down but to roll it up i have to play with it..it will go up an inch and than stop and have to keep hitting..is the motor bad or just a short in it? i called gm the motor is about $160..any suggestions???
Phil8616
09-08-2006, 01:05 PM
Its the RAP system (module or whatever you call it that gives you the ablility to listen to the radio and roll up the windows when you have the car off for 10 minutes (Retained Accessories) . A lot of people are having a problem with this, but I havent seen any way to fix it, besides maybe replacing the RAP system, if thats possible? Mine has been acting up for a month now, off and on, usually when its hot outside. Now I put a new Headunit in and its worse...Hopefully someone will solve this dilema. Its really embarrasing when your bumpin your shit and all of a sudden the radio just shuts off. Ha
-Philip
2001SSBOY
09-08-2006, 01:09 PM
yah no kidding dude..i ended up rewiring my whole system so didn't have to worry about that.
Camaroz
09-08-2006, 01:30 PM
Your window motor is toast. I think autozone has lifetime warranty window motors. You can find plenty of info just search :thumb:
WhiteBird00
09-08-2006, 02:09 PM
Just because the BCM doesn't look physically damaged doesn't mean it's not the problem. Each of your symptoms can be caused by other problems but taken together they indicate that the BCM is the most likely source of the problem. The only other thing that they could have in common is the door latch switch. If it is shorting out then it could be causing the BCM to mistakenly turn the RAP on and off.
2001SSBOY
09-08-2006, 03:30 PM
yah buy anything from gm and you get ripped..i'll try them thanks
Camaroz
09-08-2006, 07:31 PM
Hmmm, I'm not shitting you on this. The BCM looks Brand spanking new everything was so shiny!
schmidt69
09-09-2006, 03:05 AM
wheres the BCM at so i can look at mine, and also wheres the RAP system or whatever, ive been having this problem for sometime and im getting sick of it. thanks
WhiteBird00
09-09-2006, 04:57 PM
The RAP system is controlled by the BCM - there is no separate controller. The BCM is a black box about the size of a paperback under the dash on the right side behind the glovebox. Looking at it won't tell you a thing - it could be completely dead and still look brand new.
schmidt69
09-11-2006, 12:56 AM
where can i get the BCM part.
maybe from a totaled car
Mike @ FbodyAudio
09-11-2006, 08:20 AM
guys, check your grounds too. There are 2 grounding points at the dash, one behind each kickpanel, near the bottom of the dash. If one of those works it's way loose, all sorts of weird stuff happens.
also, for those looking at swapping BCM's, make sure you research that issue before buying one from a junk car. I'm not sure what years are compatible with others, and also, your key's resistor value for VATS is stored in the BCM. I think you can only program your key into a brand new, never used BCM. Once a BCM had been used with a key, I think it's locked in. Again, I'm not 100% on this, so do some research before spending money on another BCM.
mike
WhiteBird00
09-11-2006, 08:27 AM
Yes, you're right Mike. A BCM can only be programmed once for the VATS system. If you install a used BCM you have only a one-in-fifteen chance of getting one with the same resistor value. Otherwise, you'll have to install a VATS bypass kit to be able to start the car.
There were only two different BCMs used in 98-02 F-bodies - one with the factory alarm and one without.
schmidt69
09-14-2006, 12:07 AM
ok so you think its my BCM, all of a sudden when im driving my stereo shuts off and my windows dont work, but if i hit the top of the monsoon deck it sometimes comes back on, or at least try to the antenna will come up and go directly back down, could this be the grounds. or is it definetely the BCM. also my hatch button stopped working on my key fob could this be controlled by the BCM also
Mike @ FbodyAudio
09-14-2006, 07:46 AM
again, check your grounds... might be the bcm, but why spend money if simply tightening a nut is going to fix it.
Camaroz
09-14-2006, 08:09 AM
Any Idea where they are located??
WhiteBird00
09-14-2006, 08:21 AM
The radio and power windows ground at G200 which is a bolt behind the kick panel under the driver's side of the dash. You'll find a stud with a nut holding a ring terminal on the end of a black wire.
jimmy 2 Times
09-14-2006, 10:22 AM
exactly. While doing my alarm a few years ago, i noticed that this ground was not a good ground from the factory, it had some paint on it (wasn't bare metal). I just took the dremmel, and cleaned it up a bit. Your car may be simialr to this. I have never had a proble like this though.
redsscamaro
09-19-2006, 11:48 PM
I fu@@ing knew it, i knew it wasnt only my car, mine is doing the same thing, i tap it and itl come back . this shit is getting anoying
