Stereo & Electronics - Trans Am headlight bulbs????
View Full Version : Trans Am headlight bulbs????
SHINER
09-08-2006, 08:45 PM
I bought some silverstars from wallyworld and the god damn things dont fit because the original bulb is encased inside the housing..Do i have to buy the whole housing (lens, bulb, etc.)? Where do i buy them and do they have silverstars?
Blacker
09-09-2006, 02:45 PM
The firebird use sealbeam headlamps and those are H4701 and H4703. The only option is halogen. Sylvania does not make Silverstars in those model numbers. They do make the foglamps though. Another option is HID.
SHINER
09-09-2006, 02:46 PM
dammit. Thank You
JasonWW
09-09-2006, 07:47 PM
I put Silverstars in my car, but it wasn't easy.
http://www.ls1tech.com/forums/showthread.php?t=491749&highlight=headlight
HID's are the brightest, but are expensive and labor intesive.
Silverstars are definetly better than the stock lights even if you have to spend $70-$110 to put them together. HID's start at around $300 so it's "a bargain at twice the price".
From GITS.
Blackbirdws6
09-09-2006, 09:04 PM
I would convert to new housings that accept drop in lamps. The better housing and lamps will make a nice improvement over the stock sealed beams.
-Brian
JasonWW
09-09-2006, 09:12 PM
The Wagner housings and H7 bulbs run about $70 or less as the bulbs are pricey at $20 each.
The Eurolamps housing isn't any better except that it has the removable base in it. There's no difference optically between it and the Wagners. You can build the Wagners today and spend less. The Eurolamps come with lesser bulbs for under $90 shipped, but take a while to get. Then if you want Silverstars you have to add $40. So both options kind of even out.
VIP1
09-09-2006, 11:46 PM
http://www.ls1tech.com/forums/showpost.php?p=3270076&postcount=5
http://www.ls1tech.com/forums/showthread.php?t=566308
