lovin myls1
09-09-2006, 06:53 AM
My ,99 T/A factory alarm only honks it's horn...can a siren be added?Is there a better alarm out there that will work in tandem with the BCM?
WhiteBird00
09-09-2006, 05:06 PM
No, you can't just add a siren because the factory alarm uses a pulsed output to honk the horn but a siren requires a continuous output. You can add a Hornet 700T alarm upgrade (made by DEI) to the stock system for about $75. It will give you a siren, a new shock sensor, and the ability to add additional sensors such as a perimeter sensor or a glass shatter sensor. With the exception of the siren and the power/ground connections, all the wires can be connected at the BCM so installation is easy. Also, it still uses your factory remote key fobs.
lovin myls1
09-09-2006, 08:13 PM
Thanks, Whitebird00 I'll look into that. My son,who says I'm being paranoid,suggested louder horns, which may accomplish the same thing.
