Small Block & Big Block Chevy Specific - 383 help and guesstimates!!
leftme4dead
10-10-2006, 10:16 AM
I purchased a 72 Chevelle from a friend that has a 383 stroker in it. Im looking for some hp estimates and maybe which way I should take it. I dont know too much about specs and all, but here are the basics
Its a 383 stroker, it heads are the Edelbrock Performer Rpm w/angled plugs. If you need some specific specs to help with a guess, I can provide.
It also has the performer RPM cam and @.050 its like a 234/244 w/a 112lobe.
It also has a Holley 670 carb.
Im just looking to see if you can give me a guess on what you think the power is currently untuned, and what you think I can get out of it by tuning.
Im also wondering what would be the ideal sized carb for the best power gains, the previous owner was going to go with a Holley 750 dual pump. Any help is appreciated!! :eek2:
WheelsUp84z
10-10-2006, 12:00 PM
well judging from the carb size, its probably got a relatively low compression ratio in terms of performance engines, the cam seems decent for a street/strip car, the heads are aluminum im assuming? im gonna guess around 300-325 horses at the flywheel, its hard to make an accurate guess with the little amount of info provided.
leftme4dead
10-10-2006, 02:03 PM
I know the heads are aluminum. I dont know what else to post so someone could give a better guess. The only thing I do know is my friend said his setup is similar to another edelbrock setup that is producing 500ish hp. I guess I just need to get it dynoed. I have run a 12.7 so far in it, thats with limited slip, 2.73's. What is the largest carb you would put on a 383 period, or does it depend a lot on other factors?
fockabela2001
10-10-2006, 02:18 PM
hey bud on my 383 i'm runnin an eldelbrock 750cfm...that was the carb eldelbrock told me to use on it....holley recomended a 750 somethin lol....i'm makin 453.. hp at the flywheel.forged rods eagle pistons...ported and polished heads.not aluminum..can't remember the specs on everything but the cam has somethin like a 500 lift..i have all the papers if you would like me to send u specifics on it..roller rockers..weiand single plane intake manifold..
leftme4dead
10-10-2006, 02:33 PM
I have the specs on the cam and heads in this edelbrock brouser. I know my friend said he was going to with a the 750cfm. He also said about getting a double pump or something, or that the holley 750 already had it. I know the motor also has forged internals, I need to try and find out exactly what is in it.
fockabela2001
10-10-2006, 04:21 PM
yeah brother either that or take it to a dyno lol
1bad83ta
10-11-2006, 06:11 AM
I would definetly ditch the carb and get a larger one.
leftme4dead
10-11-2006, 11:17 AM
I think I am having it dynoed sat., would you guys recommend anything larger than a 750cfm??
fockabela2001
10-11-2006, 02:42 PM
i personaly wouldn't cause i know mine makes 450 plus with a 750 on it and that was recomended by both holley and eldelbrock...me personally i wouldn't
