Small Block & Big Block Chevy Specific - 383 Build HP Estimates?
View Full Version : 383 Build HP Estimates?
jumpmanmb87
10-11-2006, 04:31 PM
Any estimates??
Bore = 4.030
Stroke = 3.75
rod= 5.700
Eagle Competiton Rotating Assembly
Flat tops with 11.1 compression
AFR 195cc Street Eliminators 64cc Chambers
Comp Cams Xtreme Energy XR270HR-10 Hydraulic Roller Cam
Lift: .495''/.502''
Duration: 270°/276°
Comp Cams Pro Magnum 1.6ratio rockers
Edelbrock RPM Air Gap Intake
Speed Demon Carb 750cfm
Villain281H
10-11-2006, 05:31 PM
I'd say 450 hp at the flywheel. Run a good convertor (or manual) and a 3" exhaust to let it breathe, and with decent suspension you'll find the high 11s!
Derek
Autometer
10-12-2006, 10:53 PM
Dyno2000 put it at 465/501 but no telling what your heads flow. :dunno:
CNC BLOCKS N/E
10-13-2006, 12:00 PM
We built and engine last yeear and dynoed and is simialr to your only we used a hydraulic flat tappet cam and it was 10.:05 on the compression
Here is the link
http://www.chevelles.com/forums/showthread.php?t=106715&highlight=DYNO
Stroked SBC
10-15-2006, 03:08 AM
I'm gonna guess 475+. We recently dyno'd a 383 with a set of Pro Comp heads with some minor porting(so-so head), air gap intake, hyd flat cam 234-244 / .488 .510, 9.8-1, and it made 455.
JTM
10-16-2006, 12:49 PM
Why such a small cam? Whats the lift come out to after the 1.6's? Have comp custom grind you a cam for your heads and application. Those new heads flow quite a bit, with a diiferent cam you would be well over 500.
SSZ
10-16-2006, 09:02 PM
I would suggest picking a hyd roller a little bigger. I assume this is for street driving. I would look at something with low to high 230s @.050 and more lift to take advantage of those heads.
jumpmanmb87
10-17-2006, 04:41 PM
The reason is because its going to be street driven...and I dont wanna lose alot of vaccuum because of the duration, thats why im going with the 1.6 rockers do think I should bump up the cam one size?? but then im afraid im going to lose bottom end which I want for the street.
Thats the next size cam
Xtreme Energy XR676HR Hydraulic Roller Camshaft Only
Lift: .502''/.510''
Duration: 276°/282°
RPM Range: 1900-5600
SSZ
10-17-2006, 07:35 PM
That one will work better IMHO. I run 230 236 @.050 duration and have absolutely no problem with vacuum or power brakes. The extra cubes from a 350 help tame the cam. You wont lose any bottom end. I know I have plenty. So does my driveway :eek2:
YenkoST
10-19-2006, 01:21 PM
AFR did a dyno with the same setup but a 236/242 cam and 10.4 compression made 523 hp. So, I'm going to say about 440hp. The 218/224 is a mild for a 383...I have that cam right now and wish I would have went bigger.
rocket22
10-24-2006, 05:53 PM
450 mite be pushing it,Those cams seem little to me.
xr288hr cam I think would be a better.
Gregory
10-24-2006, 08:52 PM
I'll say 460 +/-15 hp at the flywheel. Torque about 450.
