Small Block & Big Block Chevy Specific - Will parts swap?
View Full Version : Will parts swap?
RelentleZ
10-12-2006, 12:10 AM
I have a 5.7l 350 out of an early 90 chevy pickup and would like to rebuild it and sell it for my other engine build. I have all the internals from a 95 lt1 and am wondering if they will work/fit in the truck block. Any ideas?
machinistone
10-12-2006, 01:16 AM
Yes crank and rods can interchange- LT1 cranks are balanced lighter so get LT1 replacement pistons rather than the standard cast replacements. You will notice the counterweight is drilled/notched differently.
fast377
10-12-2006, 01:17 AM
Yea, they will work. The casting number on the lt1 crank is the same as your tbi block. Rods are different, but one can be used in place of the other. Cams will interchange also.
RelentleZ
10-12-2006, 11:34 AM
thankyou guys for you help
RelentleZ
10-12-2006, 11:12 PM
how about the cam and lifters? the lt1 had rollers and the 350 does not. can i use the rollers and lt1 cam in the 350?
82whitez28
10-13-2006, 12:20 AM
uhmm the cam will work but does not have the lobe for a mechanical fuel pump... and the lifters will work as long as it is a 86 and later block i beleive....
