Small Block & Big Block Chevy Specific - LT-1 ecm on L-98
View Full Version : LT-1 ecm on L-98
98_blk_Hawk
10-14-2006, 09:08 PM
Has anyone put a LT-1 ECM and harness on a L-98 and got it to work. I am having trouble getting a modded L-98 to run and am exploring options.
ggk
10-17-2006, 10:41 AM
just get a big stuff 3 and forget about the lt1 ecm
tons of options you will love it.
WheelsUp84z
10-17-2006, 01:59 PM
i dont know for sure but i dont think that it will work out because the lt1 is ran off of an opti-spark, but thats the only real reason i can think of
ulakovic22
10-17-2006, 03:13 PM
You would have to use LT1 sensors and also find something for your cam position signal. There are options out there, like a crank trigger and then a cam sensor in place of the distributor or a dual sync distributor. I'm not positive on what exactly the LT1 PCM needs, but those two options are something to look into.
Strokinit383
10-30-2006, 02:29 PM
This may or may not help you, but its worth a look.
http://www.lt1intake.com/services.htm
MattODoom
10-31-2006, 12:20 PM
There are a couple guys over on TGO running L98 TPI motors on the 00-02 LS1 PCM, which is the same PCM that powers the L31 5.7 vortec of those years. They use the vortec distributor and vortec timing cover (which has a crank sensor in it).
Check it out:
http://www.thirdgen.org/techboard/tpi/383323-tpi-obdii-thoughts-opinions.html
