cwaldt
10-17-2006, 10:41 AM
Should I go with mild steel or chromoly. I figured the mild steel would be stronger but I'm not 100% sure. If the chromoly is as strong or stronger I'll go that way for wieght reduction.
ulakovic22
10-18-2006, 06:58 PM
I would go with chromoly. It's lighter and should be stronger than mild steel. It will flex more, and will tend to bend rather than break like steel does.
TimTaylor75
10-22-2006, 12:15 AM
I've been trying to figure this one out as well (check my poll/thread in the Handling section). I think I've finally made the decision to go with a regular mild steel and pick up Madman's motor plate. Mainly, due to the his suggestion of using a k-member with no motor mounts to allow for more header clearance. Granted it will add a bit in terms of money, but the added benefit of more space and strength of the plate setup will hopefully be the best of both worlds.
