Out1aw
10-22-2006, 01:57 PM
I am currently looking into a new driveline for my 94 Z28 and am debating on 3 different setups, either a 383 LT1, SBC, or LS2. I would rather do the SBC swap, hence the reason I posted this here. I would like to do a ZZ4 swap with a 700-R4 transmission. This will be a daily driver also, but will have a lot of track time. I will also be doing a nitrous setup as well. Here are the questions I had:
1. Are there any major fabrication tools required for such a swap (i.e. plasma cutters, welders, etc.)
2. I will be getting the BMR K-member and a cowl induction (4") hood, but other than that are there any other modifications needed to fit the motor in?
3. Will this setup line up the shifter for the 700-R4 to the stock location with no modification?
4. Will the driveshaft need to be changed or modified to bolt up to the 10-bolt?
Any other input or advice would be great also. Thanks.
