Small Block & Big Block Chevy Specific - Vortec manifold on older block and heads?
BRIANLT1
10-26-2006, 12:16 AM
What has to be done to mount Vortec manifold on standard heads??? Is it bolt pattern or port height??? Thanks
Exotic Performance Plus
10-26-2006, 06:21 AM
The intake bolt angle is different on the Vortec heads, as the bolt pattern is horizontal, instead of at an angle on the older heads. Basically, the Vortec intake won't work on older heads.
The Vortec heads are only about $500.00 complete, and they flow much better than the older heads. The downside to them is that you do need a Vortec spec intake manifold. Edelbrock has intakes for the Vortec heads. Bob
Dzman
10-29-2006, 10:19 AM
U can find new vortec intakes for around 150
82whitez28
11-02-2006, 11:41 PM
from the looks of it he has a vortec manifold already that he wants to mount on a set of older heads... my suggestion is trade someone for the right manifold u need or breakdown and buy one it is too much work in my opinion to get the manifold to work on your application
Brandon35thSS
11-03-2006, 01:35 AM
the vortec intake will work if you drill the extra bolt holes in it. it is however not worth the headache of trying to get it to seal properly so its a much wiser choice to just get a new intake imo
chevydad
11-03-2006, 10:59 PM
what intake are you trying to use? i may be interested in tradeing you. i have an edelbrock performer sitting here not being used. it's for the old style heads
