Small Block & Big Block Chevy Specific - Is there another header besides the 2455 for bbc
Rundeep66
11-04-2006, 09:15 PM
Is there anything else I can use that is a little bigger than the 2455. the header is only a 1.875. This header was not intended for the swap but it wirks. Is ther anything else out there maybe with a 2 1/8 tubes and 3 1/2 out
machinistone
11-04-2006, 11:53 PM
What is the application?
Rundeep66
11-05-2006, 01:38 AM
BBC in a F body 572
ulakovic22
11-05-2006, 11:06 AM
Hooker makes a 2285 and 2287, but I'm not sure how they fit. They are a 2.125 primary made for older BBC camaro's, Nova's and Vega's. Not sure about the price tag though. With the 2455 you get 2 in primaries and the driver side slides in no problems, passenger side is the only one that needs a little work and they're only $150
Rundeep66
11-05-2006, 10:36 PM
thank you
1969CAMARO
11-23-2006, 06:19 PM
you will have to notch the bottom of the header flange prior to installing them, dont buy them coated , you will break the coating grinding on them, the 502 and 572 use big head bolts and will not clear..
JUICED96Z
11-23-2006, 11:48 PM
KOOKS? Can't remmeber the specs but I know the make them for a BBC in a 4th gen.
