Small Block & Big Block Chevy Specific - having problems with 283 rebuild
treenabe
11-05-2006, 10:13 PM
I rebuild my 283 out of my 61 Impala. It runs good, but I am getting a lot of gas in the oil. I assume it is running rich, but have no idea about adjusting the carb. It has a 4 barrel (I think Holley) carb. There are two adjustment screws visible on the front of the carb near the base. Anyone know where to start? Also, it is a new fuel pump. is it possible that that it is leaking into the crankcase. Have several other problems, but I will hold off for now.
Thanks.
427TWINTURBO
11-06-2006, 09:43 PM
how big is the carb? maybe you have too much carb for your engine, is the carb leaking (puddling fuel in the intake) after you shut the engine off? the 2 screws you are referring 2 are the mixture screws.
BrianEsser
11-07-2006, 08:47 AM
New pump or not, I would first suspect that. If it was running so rich as to fill the oil with fuel your eyes would be burning just standing near it.
01WS6/tamu
11-11-2006, 08:21 PM
fuel pump es no weno or mongo rich problem
GOaT Cheese
11-12-2006, 01:16 AM
Deffinately check that fuel pump, before you wash the bearings and have to rebuild it again.
