Stereo & Electronics - anybody got a spec/deminsions drawing of the
CULATR
11-07-2006, 10:58 PM
stealth box or similar ...drivers side box for one 10" sub ? I believe there is a similar design floating around to the stealth box design, there's one on ebay for cheap but i would rather build my own and seal it up right for cheap ....anybody know or got a drawing of it ??
muddmanWS6
11-08-2006, 03:50 PM
yea im thinkin about doin my own to.
anybody?
thingthatgoes
11-08-2006, 04:38 PM
I did mine, I took some pieces of styrofoam and kept cutting them to fit. It works great as a template. Then just cut up some MDX and it works great. My only advice is that if you want to maximize the volume, you will have to make quite a few cuts with quite a few pieces.
DrewSG
11-08-2006, 04:44 PM
How much did it end up costing you?
thingthatgoes
11-08-2006, 09:22 PM
just a $7 sheet of MDX at home depot. I heard that this was the best wood to use. I would figure that birch would be better but I don't know. Anyway, I had alot of different angle cuts and about 8 sides, like I said, maximize the space. It sounds good though, but you need a good speaker and amp to make a difference in the monsoon amp'd option stereo.
Sgt. Spuds
11-08-2006, 09:45 PM
I made mine, just use cardboard as a template.
