Small Block & Big Block Chevy Specific - CAM Question?
75bird
11-08-2006, 02:02 AM
I have a 383 and i want to know if i take out the cam...would there be a part number on it...so i can look up the specs..?
75bird
11-08-2006, 03:16 PM
Any HELP?
jmm98LS1
11-08-2006, 03:43 PM
Nobody will be able to give you a straight answer because I don't think all manufacturers etch grind numbers onto their cams. I know the aftermarket cam that came out of the 355 in my truck didn't have any #'s on it, but the comp cam I replaced it with did. Only way to find out is to pull it and see. :)
75bird
11-08-2006, 04:15 PM
alrite...thanks for the information...
1989GTA
11-08-2006, 08:50 PM
If you can find someone in your area that has a "cam doctor" they can run your cam through it and give you the specs. Here in Southern California Chet Herbert Cams does it for free.
75bird
11-08-2006, 09:59 PM
Thanks for all the info....i got the cam out already and it did have a part number...
