z28C4maro82z
11-10-2006, 07:55 PM
Anyways, just traded my duals for a dual cutout ORY, and well yeah. BLAH. I wired it through the firewall and directly to the battery. Still has the fuse (remember this is not blown) I have it grounded right in one of the 10mm bolts near the shifter area. The cutout wires are run through the floor. Now here's my grief.
I get in the car, and turn the key to accessory. I flip the cutouts open and close. They work 2x. Then I start the car, open 'em, close 'em. Works. Now that's a total of 3x that I do this. Now I get out of the car, and no more than 2 minutes later, hop back in, and nothing. The switch doesn't work now.
I took off the bettery terminal, and re soldered it, and put it back on. Nothing.
I checked all the wires, no problems. Both cutout wires still hooked up, no problem there. I test the switch, and both cutouts, both are getting juice. Now I test the fuse in the wire. (remember still not blown). I check the fuses in the box, no problems there.
I got rid of the QTP cutout in my old I-pipe because this happened 3 other times to these damn switches. WTF. Did I just buy myself back into another problem??????
Any help at all is much apreciated. I would love any help anyone may be able to give. Thank you
Chris
Chris
