raceking33
11-11-2006, 10:42 AM
okay I have had been waiting for someone to ask but no one has yet........... how are all you guys that did the swap from a v6 to carbed v8 running your fuel lines??? are you still using the eletric fuel pump?? did you replace the fuel pump in the motor??? THANKS!
Strokinit383
11-11-2006, 04:06 PM
I upgraded my intake pump to a 255lph walbro, left only the metal fuel and return lines. I removed the plastic lines that ran into the engine bay but kept the male ends of the clips that attach to the hard lines. I then ran Earls rubber super stock hose to a return style regulator with two outputs in the engine bay. I adapted the male clips to the end of the hose and AN fittings on the other end for the regulator. Instead of routing the hoses up through the stock location i used a hole saw and drilled a hole underneath the clutch fluid res. and routed them along the top of the firewall so that they were hidden. Hope this helps.
