Generation III Internal Engine - Need help-car failed emission test
TexassTA
12-01-2001, 10:14 PM
Since the last inspection,I have installed a T-1 cam and FLP headers with cats,stock tuning. The low rpm test(hydrocarbons) was real high at 696.I have a HPP3 and a ported maf that I can put on the car. Will that help much? Any suggestions?Thanks
Raughammer
12-01-2001, 10:40 PM
Whoa, before you do all that.
1. make sure the car is fully warmed up.
2. New oil in the crank case?
3. new plugs?
4. The ported MAF "should" lean it out a bit and that will help you some.
5. Set your idle up just a bit..(use a piece of tape, adjust the screw, etc...)
6. Your O2 sensors could just be going bad. LOTS of times when headers are added to a car.. the sensor go bad. This is usually because they got some "bad" substance on them while they were out of the car. Such as ANYTHING with silicone in it, or grease ... man it seems almost ANYTHING will contaminate them. If you can install your rear O2 sensors in the front and give it a go.
They also make an additive that will ower your emissions. It really does work. About any parts house sells it.
Good luck.
Dave
12-01-2001, 11:49 PM
Certain inspectors with ahem, negotiable $cruples can be per$uaded to pa$$ anything - even here in California... <img src="images/icons/wink.gif" border="0">
Make sure your AIR pump is running, even if you have to jumper it on - secondary air reduces HC. Perhaps an oversized pump? Remember, it's reading percentage, so if you double the airflow out the tailpipe, you cut your HC in half...
Toxic Texan
12-02-2001, 12:05 AM
Make sure you drive it around and get it nice and warm before the check. And $$$$$$$ and <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" /> works wonders. <img src="images/icons/grin.gif" border="0">
99 Black Bird T/A
12-02-2001, 10:33 PM
A 160 stat with the HPP3 160 fan settings might not let the car get warm enough. What temp stat and fan settings is the car running?
Patrick G
12-02-2001, 10:37 PM
My cam is similar (221/224 .560/.560). Low idle speed could really be killing you. My car was 275 ppm HC on low speed and 9 on high speed (2500 rpms). My idle was at 750 rpms. Raising it to 900 allowed it to pass.
TexassTA
12-03-2001, 01:34 AM
The car was good and hot.I`ll try some of those things you guys suggested.Thanks
TexassTA
12-03-2001, 08:08 PM
I`ve got new plugs and changing the oil tomorrow.I`m trying some of the additive too.Also going to raise the idle speed and try again.
Beeler422
12-04-2001, 11:57 AM
Emissions tests??? I didn't even know we had that in Texas. I've never had it.
Pro Stock John
12-04-2001, 11:59 AM
A MAF T could help, raising the idle could help. Rigging the air pump to stay on will for sure get it to pass.
Camaroholic
12-04-2001, 12:01 PM
[quote]Originally posted by Firechicken WS6:
<strong>Emissions tests??? I didn't even know we had that in Texas. I've never had it.</strong><hr></blockquote>
The big counties (Tarrant, Dallas, Harris, etc) and surrounding DO have sniffer testing. The smaller counties do not.
-Andrew (smaller county resident - we let all our crap blow in to Oklahoma <img src="images/icons/grin.gif" border="0"> )
Linear Velocity
12-04-2001, 05:00 PM
Dave, I may need some of your help, I'm putting some Longtubes on and a B1 cam, this will definitely not pas California emissions, post info here and or email me. Thanks. ~Tony
John B
12-04-2001, 11:25 PM
Last time I went through the sniffer with my K5 Blazer it was idling low (about 600RPM) for some reason that day and since I had previously removed the CAT, I just stepped on the gas pedal to bring the idle up to about 1000 RPM (test maximum is 1100RPM) to ensure the ECM could adjust A/F based on the O2 sensor feedback and it worked just fine <img src="images/icons/grin.gif" border="0">
Beeler422
12-05-2001, 01:10 AM
Can't you just get your inspection done in a county that doesn't require it? Do you have to have some sort of sticker saying that you had emmissions tests done? How do they know what county you live in?
cantdrv65
12-05-2001, 08:10 AM
In an emissions testing county you get a green inspection sticker signifying the emissions test pass. In a non-emissions county you will get a red inspection sticker. I currently have a red inspection sticker and drive in Harris county. i haven't got an emissions ticket yet, just two speeding tics. <img src="images/icons/wink.gif" border="0">
TexassTA
12-06-2001, 08:21 PM
I tryed buying a sticker and was told no thanks. Since I have to show them proof of insurance(which tell them what county I live in) I wonder if I can get it inspected out of county?Anyone know? Maybe I should have got the <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" /> cam. Let me know what you guys think. Thanks
[ December 06, 2001: Message edited by: TexassTA ]</p>
99 Black Bird T/A
12-06-2001, 08:58 PM
TexassTA,
How about giving us a full list of all of your engine mod's? Stat and fan settings can wreck havoc with emissions testing. When was the oil last changed in the car? What temp was the car at?
Could leaning the car out with a MAFT, get the hydrocarbon's down enough to pass anyone?
BIGBOS
12-06-2001, 09:00 PM
Will I pass emissions...and when they do emissions testing what rpms do they take it up to??
I have a MAFT and I could really lean it out....
my cam is a
222/222 .563/.563 112lsa
other little mods are in sig...
TexassTA
12-07-2001, 08:29 PM
I have a 180 degree t-stat and the fans turned on at 160 degrees. I used a stock desreened maf.TR-6 plugs gapped at .038.MSD plug wires. The rest of the mods are in my sig.
V6 Bird
12-08-2001, 08:02 AM
Your insurance has nothing to do with what sticker you get here in Texas. It is where the car is registered. You get a different registration sticker for the emisssions counties. They use that to give you the right sticker for the inspection. I used to do inspections... <img src="images/icons/cool.gif" border="0">
