Stereo & Electronics - weres the space in the firewall? ordered L7 and kx1200.1 amp
jattgunman
12-10-2006, 12:53 PM
i ordered some subs last week . i got one 12" L7 and a kx1200.1 amp(1200 watts) .. i still haven’t bought the amp install kit .. but im probably gonna go with a 2 gauge setup .. my subs are coming tomorrow .. and i was wondering how do i get the red(+) wire to my battery ... is their any space in the firewall so i can feed the wire through? . also i am going to make my own box and i was wondering do anyone have the plans/blueprint on how to make a sub box for a 01 ss .. if you do can you post them or pm to me
thanks
bow125106
12-10-2006, 12:58 PM
there is a place (dont know if they are a sponsor or not) that makes custom boxes for the ls1...they look really nice and fit really well from what i have seen...Those L7's require alot of air space, so fiberglass might be a good idea to get the most out of what space you have...
bow125106
12-10-2006, 01:01 PM
here is a thread on the firewall question
http://ls1tech.com/forums/showthread.php?t=576823&highlight=firewall
blackbird007
12-12-2006, 01:51 PM
So did you get one or two L7's? And depending on what your going for will depend on your space requirements. I have had one L7 for a while and went from a custom SPL box that took up the entire trunk space to a small sealed box that is portable. They both sound awesome as long as you build them to fit the speaker.
Here is my old SPL box: Never got around to sleeving the port, but it got the job done.
http://img.photobucket.com/albums/v698/mcharb007/System/IMG_0141.jpg
The sealed box I use now: I wanted to retain the use of my t-top holders so I wanted this box to be easily removable.
http://img.photobucket.com/albums/v698/mcharb007/System/IMG_0246.jpg
http://img.photobucket.com/albums/v698/mcharb007/System/IMG_0247.jpg
bbal4now
12-12-2006, 04:20 PM
blackbirds system works. and if you want a way to keep your t-top storage then that is great. The truth is though, our cars are so incredible with subs becasue of the round hatch-back design. The sound can travel very fluidly when facing the rear glass. It acts as a wall esentially bouncing the base staight to the front. If you place your sub firing sideways into your t-top rack you will hear less crisp base and more rattling. Here are some pictures of what I am talking about.
01FormulaTA
12-12-2006, 04:31 PM
its on the left side(same side under the hood as the battery), all you have to do is remove the computer and there is a rubber grommet behind it, I just did my system install 3 days ago and thats the best place that I found......
Sk8runeg
12-12-2006, 11:02 PM
That is not true. Subwoofer Bass is Omnidirectional. That means it travels in every direction no matter wat. However, certain frequencies can only be heard from further away, typically lower frequencies. There for by facing the sub to the side the sound has to travel further to get to you, making it further away and making it sound better. When people build custom boxes like you pictured, it is usually for show, or their subs are just so powerful that it doesnt matter which way they go.
I have a custom box i built which angled the subs with the rear hatch and looked great and all, but in all reality when i Put one ten facing sideways in the t-top area it was so much better than the 2 tens facing forward wiht the custom box.
-Scott
blackbird007
12-13-2006, 08:21 PM
-Scott
I agree, before mounting my amp and cap to the box, I tested the system with the sub facing the glass and facing the side. I decided to let it face the side because it sounded so much better that way with my particular setup.
jattgunman
12-14-2006, 11:23 PM
thanks guys for all the help i dont think i woulda found that firewall hole on my own..and takin out and puttin back the computer wasnt easy either..got all the wiring done now just tryin to make the box which is gonna look like the subthump one or atleast i hope
