Stereo & Electronics - window motor
tunit
12-16-2006, 04:06 PM
Does anyone know how hard it is to put on a window motor for a 2001 Trans Am? I've also heard that aftermarket motors go out really fast after installing them...anyone have any suggestions? Thank you in advance!!
Sticky:http://www.ls1tech.com/forums/showthread.php?t=303776
Specifically:http://www.ls1tech.com/forums/showpost.php?p=2977771&postcount=18
Easy to do.
tunit
12-16-2006, 05:59 PM
hey thanks for the reply...now i dont have to pay labor!! just one more question...should i go with a motor from the dealer or just get a cheap aftermarket? aftermarket is about $70 and from the dealer is about $180...but one mechanic told me that his experience with aftermarket are horrible
2001NBMZ28
12-16-2006, 06:22 PM
Get one from Auto Zone, cheaper than the dealer and has a lifetime warranty. Helped install several and they work fine.
Many people on here recomend the seimans or dorman aftermarket window motor, which should both be available at AutoZone.
tunit
12-16-2006, 09:09 PM
alright, ill give one of those a shot. i cant pull the pics up for the firebird...the camaro has the same setup correct?
2001NBMZ28
12-16-2006, 09:17 PM
Yeah, the metalreviewcentre site went away for some reason...basically the same, except the switches on the door panel are a little different. You can do it, just take your time...after you've done it once you'll be an expert. :)
