Stereo & Electronics - jensen 9411 monitor ?
View Full Version : jensen 9411 monitor ?
6-Speed Terror
01-07-2007, 04:22 PM
i just installed it yesterday and i cant seem to get a pic on the tv tuner everything else works fine and it even worked without the pink wire connected. evrything was connected right and you can hear the station real clear but just no pic, when you change to cd or radio tuner the screen works fine. anyone hava a similar problem.
Emoney97ss
01-07-2007, 04:32 PM
did u use the code that deletes the pink wire?
6-Speed Terror
01-07-2007, 04:59 PM
yeah i used the code would that mess up the tv tuner?
Emoney97ss
01-07-2007, 10:03 PM
to be honest i don't know cause i have the 9311, but i don't think it would turn it off then try the tv tuner, and see if i works
6-Speed Terror
01-08-2007, 02:38 PM
found it turned out the video cable from the countrol unit got loose and was not transmitting video sig to the h/u
