Street Racing & Kill Stories - LT1 vs EVO *vid
camzaro28
01-08-2007, 11:11 AM
he took me down :cry:
mods: stock turbo, bolt ons, cams, meth injection.
FYI, we ran these passes consecutively and my bottle pressure dropped after each pass, obviously.
click here (http://www.mistercmk.com/camzaro28/EVOvsLT1.wmv)
My only excuse is after 100 my car started breaking up bad. Thinking it is clogged injectors.
97blkz
01-08-2007, 11:15 AM
EVo's can be pretty quick, I'd take a shot though!
ScreaminRedZ
01-08-2007, 11:15 PM
Damn, looks like a fast ass Evo.
WRX-ERROR
01-09-2007, 08:15 AM
How much your spraying? Nice runs. Gotta love daytime videos. :drive:
Electric
01-09-2007, 12:08 PM
Nice vid (daytime rules). Looks to be very close race!
GXPPOWER
01-09-2007, 02:10 PM
an evo can have the stock turbo and still gain alot of HP with the boltons
burnzilla
01-09-2007, 02:31 PM
yeah cam, I could sort of hear your car breaking up some at the top of 3rd.
Stall looks like its workin great.
Good runs though, I didnt think that Evo's top end would be as good as it was.
What do those redline at with the turbo?
jamesSS
01-09-2007, 03:05 PM
an evo redlines around 7 grand. after a few boltons and a tune, you can raise it up higher.
Electric
01-09-2007, 03:13 PM
Redline on the tach says 7000 yet the actual rev limit is set at 7600. Going over 7000 with the stock cams is worthless. With a pair of cams, you can rev to 7500 and things will be dandy. Dont confuse stock EVO top end with an EVO with some cams. They fix that completely.
WRX-ERROR
That turbo starts to run out of gas around 5500rpm to 6000rpm. By redline it's running around 17psi to 18psi.
Electric
01-09-2007, 03:19 PM
No it doesnt. Its runs out of steam around 6500-6700, where boost falls to 19psi. It will sustain that up to 7500+ and the car still makes pretty good power up past 7000. Every fast stock turbo EVO revs to around 7300-7500.
ULTIMATEORANGESS
01-09-2007, 04:22 PM
who was roasting those tires? :jest:
it seems a few times you were starting to pull away then you died.
BayAreaSS
01-09-2007, 05:34 PM
Nice vid!!
You can tell in the vid that your car began to die. You pulled him and then fell flat.
camzaro28
01-09-2007, 05:45 PM
Yeah, injectors are next. Then I hope to run into him again.
Pisses me off that I could pull him down low, then he would just fly by me.
Eh, oh well.
XtremeBBQ
01-09-2007, 09:02 PM
nice runs and vid.
man that evo sounds like SH*T bouncing off the limiter like that.
sounds about as mean as a 50cc dirtbike pinned.
Quik Z06
01-09-2007, 10:44 PM
Haha having owned an Evo with cams I can tell you they pull pretty hard up top, the awd thing is way overrated. My Evo's redline was set at 8200rpm, but I had the valves, springs etc. They only drop in psi up top if they are not reflashed or your not running a boost controller. My wife actually ran an Evo 9 this weekend in her Z06 and got beat, not by much she satrted to catch him by the 1/4 mile mark and shes on some bald tires :) But they are fast, peolpe underestimate them a lot IMO.
firebirdvert305
01-09-2007, 10:58 PM
nice runs and vid.
Thats not a rev-limiter is a 2 step (stutterbox) which allows him to build boost in 1st gear, so you launch off the line with virtually no lag, and full boost soon as you slip the clutch. Its a great feature when combined with traction. I usually build around 15-18 lbs of boost off the line when im on slicks, it all varies tho as to where the stutterbox is activated i set mine to 6500 rpms.
jamesSS
01-09-2007, 11:06 PM
yeah, all new evos come with it. i guess its called launch control. first time my buddy did it i thought he was bounching it off the limiter but i guess it will hold that rpm till you drop the clutch. its a neat little feature. still a good race.
XtremeBBQ
01-09-2007, 11:40 PM
guess 2 steps in little turbo 4's dont sound as good as ones in v8's.
should have made it when the 2 step engaged it raised a pink flag and hazards would start flashing. would be more appropriate.
bmfgsxr
01-10-2007, 01:09 PM
good runs man.. evo's are fast little cars. that looked like a great place for racing too.
WRX-ERROR
01-11-2007, 09:58 AM
Sorry for the miss information then. My buddies 03 EVO starts loosing boost around 5500rpm and is around 17psi by redline. Seems to be inline with that turbo on a WRX also. But you would know better then I since you have one. :)
Electric
01-11-2007, 10:21 AM
Its cool. Your friend probably has a very bad boost leak to be causing that taper that early.
Juiced
01-11-2007, 12:03 PM
03-04 evos had a 9.8 exhaust housing no the larger 10.5 or the RS and all 05 Evo's (yes it make a huge diffrance)
I reved my stock cam evo to 8k (held 25 psi) and made 400whp on the stock turbo, with my 37r i took it to 8500 rpm with stock internals and valvetrain at 32psi, it walked a maggie GTO and a Cammed WS6 on a 150 shot.
They can be fast but be prepared to spend alot of money to get them there andeven more to keep them running, tranny's and clutches get expensive quick.
TransAminal
01-11-2007, 12:37 PM
You would have slaughtered that riced out 4 door if your motor had been running right. You pulled him hard, but then he got you back on the top end when you started breaking up.
Thats also the worst sounding car I've ever heard, sounds like a dirtbike when he launched. Thats what happends when you have a 4 cylinder, it sounds like garbage :eyes:
Electric
01-11-2007, 12:50 PM
Sounds like a ricer excuse to me :chug:
TransAminal
01-11-2007, 03:37 PM
Sounds like your an asshole to me.
Get the fuck out of here already, nobody like a stupid ricer witha 4 door fag car.
Electric
01-11-2007, 03:45 PM
Thats what I thought!
TransAminal
01-11-2007, 03:46 PM
So why don't you leave already??
You fit the description perfectly, stupid ricer with a 4 door fag car... :gtfo:
Cole Train
01-11-2007, 03:55 PM
i raced a pretty heavily modded Evo from a 20 roll. had his ass bad 'til about 65-70 and rolled right by me like i had an anchor draggin' out back. He is said to be running close to 500 hp on motor and a 100 shot. he didn't get his boost up when we went so it took him a little bit to catch up. Then he made some smart ass comment about"Nice Cavalier" I gave him the bird and told him to fuck off. It would have been one thing if he hadn't been a dick 'cause it was a fast car but after that i had no respect for the guy. Car yes but not him. ~cole~
NIevo
01-11-2007, 03:58 PM
I hate people like that. It gives everyone with "said" car a bad name. 100 shot is pretty big for an Evo, most run 50-75 shots.
NVR KNO
01-11-2007, 04:08 PM
we have a few guys around here with some pretty nasty evo's and sti's. ive had my butt handed to me a few times by them and i still come back for more. its all in good fun. they are pretty cool about it though too.
camzaro28
01-11-2007, 05:19 PM
Well the Evo went to the track last and ran a 12.2@113 and then a 12.3@114. Said he was having problems with the boost. Something along the lines of it was cold out so the meth was not working.
When he ran me he "says" he was at 31 psi, but last night he was only running 26.
Electric
01-11-2007, 05:28 PM
Yah those are very weak times for meth. Ive obliterated those times without meth.
unit213
01-11-2007, 06:18 PM
Stop bashing members.
Consider this your final warning.
MisterCMK
01-11-2007, 08:42 PM
Good race Brian. Time for heads and a cam. :D
sdm1234
01-12-2007, 12:41 PM
holy shit both of you are fast! i was surprised to see the EVO just take off after you started reeling him in. i was also surprised when i saw your launches. at first i thought "oh great this is going to be a slaughter..." but i was amazed to see you weren't THAT far behind from the dig! good job! you win some and you lose some, but that's what makes it fun! keep up the great work!
ChrisBess99SS
01-15-2007, 11:33 PM
Nice race. Guys raced from a stop?.... Hehehe AWD Evo > RWD Camaro =O Those things are freaking quick off the line... shoot... they're quick in general
