Stereo & Electronics - How do you program fobs
RedHatRdRacer
01-11-2007, 07:06 PM
I have a 99 Camaro and i have a few extra fobs... i was wondering how to program them
blertawho
01-11-2007, 07:32 PM
i got you
1. turn ignition to the RUN position then to the OFF position
2. remove the RADIO FUSE. the fuse is located in the main fuse block. located on the left side of your main instrument panel. the fuse is most likely marked as #17
3. turn the ignition switch from the OFF position to the RUN position 3 times quicly, within 5 seconds. End this process with the key in the RUN position. (your car will respond by locking the doors, unlocking the drivers door, and releasing the hatch)
4. now, press and hold the LOCK and UNLOCK bottons on the FIRST transmitter for 15 seconds. (the the vehicle will resond as in step 3)
5. repeat step 4 for the the remaining transmitters
6. when you are finished programing your remotes turn the ignition back to the OFF position and replace the RADIO FUSE
hope that helps
Urban Legend
01-17-2007, 06:43 PM
i got you
hope that helps
Thanks for the above info. It worked perfectly.
