Ryan02SS
02-05-2007, 01:02 PM
Currently in a new 355 build and have a question. Do the checking springs currently on the market make it easier to check PTV clearance, valve net lift, and pushrod length?
I'm using Morel Hyd roller lifters, are the checking springs strong enough to depress the plunger on the lifters?
From their description it sounds like you could get away from using a solid lifter and instead use the checking springs and hyd roller lifters to check PTV, valve net lift and pushrod length?
