Ryan02SS
02-06-2007, 05:17 PM
Currently building a new 355 for my boat.
4 bolt bored .030", align honed, decked .020"
Forged rotating assembly, Eagle 4340, I beams w ARP 2000, TRW L2304 pistons w .100 dome. Setup is balanced very well.
Comp XM276HR 224/230 .503/.510 112LSA 110ICL
Morel Retro Hyd Roller lifters
AFR 190cc heads 2.02I 1.60E milled 74cc puts SCR @ 10.0-1
Edelbrock Vic Jr or Performer RPM, I have both but undecided as to which to use.
Currently have Lunati 1.52 aluminum widebody roller rockers
Holley 750 4150 DP
My question is, do I stand to gain anything using 1.6 rockers instead of the 1.5's? I've heard it's better to run the 1.6's on the intake and leave 1.5's on the exhaust as the port on SBC's seem to respond better to duration changes rather than lift. Any merit in this?
I have a new set of Crane 1.6 Gold Race Widebody's on the shelf.
I've allready checked all clearances with no problems and the valvesprings are more than capable of the added lift. 7/16" AFR studs.
I would think they might help out some as the AFR heads flow very well in the .500-.550 lift areas.
Any help would be much appreciated.
Holley 750 4150 DP
