Corvette Performance - Stock mufflers restrictive?
View Full Version : Stock mufflers restrictive?
Larry
02-06-2007, 05:17 PM
I'm sure this has been discussed but the search feature isn't working for me right now. Are the two factory mufflers a restriction? I measured the OD of each and right where the pipes come out of the muffler they are less than 2" in diameter. The ID must be less than 1 7/8". The car has 2 1/2 to the mufflers.
SPANKY LS1
02-06-2007, 05:23 PM
From what I've read over at CF, they are not bad. I decided to keep my stock mufflers with my ARH 1 7/8" headers and catted x-pipe. For me, it was a matter of not wanting my car too loud, if it costs me a few HP its worth it IMO.
Shawn
Larry
02-06-2007, 05:51 PM
I don't want noise either but seems like a little larger wouldn't have been too noisy. This car is very quiet. My 06 Mustang has a 2" ID out of the mufflers. It's a little louder than my Corvette but certaintly acceptable.
Undecided
02-06-2007, 08:59 PM
Larry I'm shooting for the fastest N/A C6 with a factory catback until the prices come down. I don't how they justify the $ they're charging for 10 hp.
SilveradoSS500
02-06-2007, 11:29 PM
I'm going to run stock muffs. with no cats/xpipe/cam with electric cutouts. It should sound stock but with alittle more... quieter than borla right?
santiago
02-06-2007, 11:43 PM
my stock mufflers are the first thing i got rid of..
Larry
02-07-2007, 05:48 AM
my stock mufflers are the first thing i got rid of..Do you have any before and after track results?
SilveradoSS500, Electric cutouts would be the ticket for track use. Sure can't crawl under the car to open them at the track without jacking.
Humm_MeSUT
02-07-2007, 06:00 AM
ZO6 mufflers aren't very restrictive at all but the others are. There are aftermarket exhuasts that flow a lot better than nonzo6 mufflers and arent loud.
FWIW, for grins I took off my modded stock Ti exhaust and actually lost HP under the curve.... peak was the same though.
Undecided
02-07-2007, 08:35 AM
Does anyone know if the Zo6 Ti catback would fit a C6? I've got a friend with the stock exhaust off of his Z. mmmmmmmmm
Larry
02-07-2007, 09:25 AM
Does anyone know if the Zo6 Ti catback would fit a C6? I've got a friend with the stock exhaust off of his Z. mmmmmmmmmThat might be the ticket. Fairly quiet and possibly no hp loss on a stock heads/cam C6.
Undecided
02-07-2007, 10:11 AM
That's I thinking, light weight & better sound! Budget racing all the way!!
SilveradoSS500
02-07-2007, 10:14 AM
ELECTRIC The QTP x-pipe with cutouts are sweet looking. Go to there web site and check out the media..... I want my Z to be queit as a can then super loud with touch of a button....
santiago
02-07-2007, 11:36 AM
stock i was 13.5@107 after putting my stock ls6 heads on t-rex cam,kooks lt's offroad x pipe and borla straight pipe catback i went 12.4@120 on a horrible 2.097 60ft.
99Z28camaroman
02-07-2007, 12:48 PM
I RUINED my 99 Z28 Camaro by removing the stock quite exhaust and putting a noisey muffler and twin outlets.
My car went from a quite extreemly fast pleasant to drive to a not any faster noisey rummbly piece of crap!
After a few months I regretted doing the change.
And it makes no difference what make muffler you use noisey does not always equal faster IMO.
My C5 Vette will be keeping it's stock quite mufflers!
Larry
02-07-2007, 01:15 PM
stock i was 13.5@107 after putting my stock ls6 heads on t-rex cam,kooks lt's offroad x pipe and borla straight pipe catback i went 12.4@120 on a horrible 2.097 60ft.That's some great gains! Not sure I want to go that far. Well, not just yet...
SilveradoSS500
02-07-2007, 10:51 PM
Bank to subject! These stock Z06 mufflers can handle a good set of headers and a cam just fine! Right? Difference between a borla, corsa etc. might be 10whp.. Right....
Gordy M
02-08-2007, 09:33 AM
Unless you go with a straight thru system like the Corsa TI off road exhasut, you will not make any significant hp than a Z06 TI exhaust. If you were to gain 2-3 hp max you would lose it in the weight difference. When GM did testing on the first Z06's they found the TI exhaust made about 2-3 hp gain over the stock exhaust. But remember that was a head and cam change essentially from a stock system.
David Gordon
02-08-2007, 10:10 AM
I ran my stock mufflers on my 01 Vette when I had around 420 rwhp 400 rwtq. It was perfect. I upgraded the heads and put in a nasty cam was at 450 rwhp and by unbolting the catback completly and redynoing again only gained 9 rwhp.
Undecided
02-08-2007, 10:30 AM
Good to know, that's what I've been hearing as well. Thanx for the info. :)
Larry
02-08-2007, 12:03 PM
Unbelieveable that these little 1 7/8 ID mufflers as quiet as they are can make 450 hp. But the proof is in the testing. Looks like I'm keeping my stock mufflers.
SilveradoSS500
02-08-2007, 12:35 PM
Keeping stock mufflers also here! Get the QTP dumps and call it a day....
Nine Ball
02-08-2007, 02:05 PM
To answer questions: C5 mufflers will not fit a C6. Mufflers are in completely different locations.
Several people have made 500+ rwhp thru factory C6 exhaust. They work just fine, but are kind of quiet.
