Small Block & Big Block Chevy Specific - Project motor
dstruble
02-07-2007, 04:17 PM
Looking for a SBC for a project! Wondering if there is a specific truck or car that came with a 4 bolt roller cam 350 with a 1 piece seal. Been searchin but all i can find is info that says it might have a 2or4 bolt or roller/flat tappet,but no specific info on a year or model that def comes with a 4 bolt/roller cam 350??? Any help is greatly appreciated!! :chug:
My01SSCamaro
02-07-2007, 06:40 PM
ok the 1 piece seal is from 87 and up the roller cam blocks are from 87 and up as for a 4 bolt look for a 3/4 ton or 1 ton truck motor most of them are 4 bolt, if you are going to run a mechanical fuel pump make sure you get a block that is capaible of putting one on it most of the vortec 350's 95-00 have the boss for the fuel pump but its not casted into the block no hole for the fuel pump rod, and if you find a good 2 bolt just get it splayed it might be cheaper that paying for a 4 bolt and tons stronger,
Ryan
dstruble
02-11-2007, 02:18 PM
thnx :chug: Any other things i should be looking for? :drive:
scramblerman
02-12-2007, 12:47 AM
Got a 73 350 4 bolt main short block for sale in a other thread in here. Its a high nickel block.
Perfect for a project motor.
camarols1
02-14-2007, 11:40 AM
I've got a 355 SBC with Vortec heads for sale.
9.8-1 forged pistons, 2.02/1.60 valves, Super Victor intake
4-bolt mains, steel crank, HOT cam kit, etc....
Let me know if you are interested
$1,600 Carb to pan
boomtubes05
02-14-2007, 02:23 PM
i got a 0010 4-bolt block .040 over 150.00 plus shipping
located pa/nj the 0010 block are a little better then the newer ones the are higher in nickel
