Small Block & Big Block Chevy Specific - Turbo BBC
Speedracer 75
02-08-2007, 06:07 PM
I'm looking for some info on possibly twin turboing my 427. It has GM Performance aluminum heads and the block has been O ringed. I cann't seem to find turbo headers or much of anything else on Rat turbo stuff. (Turbo sizing, Cam specs, Boost to compression ratio, etc). It's going in my 70 chevelle. Any help would be great.
MADMAN
02-08-2007, 06:37 PM
The headers will have to be built.
spooleliminator
02-08-2007, 06:55 PM
!. its going to be extreamly expensive because you need to get custom headers wast gate piping and many many other things! Most of the parts will need to be hand crafter. turbonetics can tell you what turbos you need and ect.
LSXNV
02-08-2007, 07:21 PM
about the headers, a few of us "traditional" pontiac guys are modifying exhaust manifolds. not real easy, but it is an extreamly durable and affordable alternative to headers. it also keeps the underhood heat in check and provides a solid way to mount the turbos. i plan to use nitrous for intercooling on race night. if things don't get put on hold again dammit :judge: .
Beaflag VonRathburg
02-08-2007, 07:54 PM
After looking at some mercruiser manifolds it looks like you could make a rather budget (I know it's hard to say that with forced induction) single kit. You'd just have to make a cross over and the rest of the kit. They probably wouldn't flow nearly as well as a tubular manifold, but for someone on a budget they might work.
Untouchable436LS1
02-08-2007, 11:03 PM
Someone a good while ago introduced me to a wonderful and knowledgeable site, and i think you would do nothing but gain from it, www.turbomustangs.com, there are guys there building they're own set of headers with little tool and fabricating know how,with just at 200$ invested in tubing and are turning out 1000hp motors with homemade kits, just food for thought, and there is an entire section dedicated to the LSX, and SBC and BBC fellas, as well as DIY articles and blowthrough section if you are going that route, hope that helps
Beaflag VonRathburg
02-09-2007, 12:12 AM
Yeah, turbomustangs is definetly a good resource.
The thing is the original poster didn't say how much money they had to spend. Maybe they should call up W2W ($ option) or build it with some friends?
1997bird
02-09-2007, 01:56 AM
I was refered to this company from my cam grinder. http://www.burnsstainless.com/
Speedracer 75
02-10-2007, 12:27 PM
Thanks I will check those out.
