Small Block & Big Block Chevy Specific - Cam selection help...
Teh Wicked
02-10-2007, 07:43 AM
Alright here is the run down of what everything is going to be. its a 63 C-10 pickup with a Gen I 350ci SBC wil all stock internals and a fresh rebuild. it will have the upgraded Vortech heads from SDPC2000 and a Eldlebrock RPM air gap intake. the carb will be you standard Holley 800 cfm.
"Upgraded Vortec head kits - features our high performance Z28 valve springs with light weight LT4 retianers, good for about 0.550" lift with a hydraulic camshaft."
now the truck WILL NEVER see the track, only thing it will be seeing is my garage and car shows and the weekend rides from time to time. I want a semi-lopey idle that is noticeable but not so lopey its a workout to drive the son of a bitch! I have been trying to research as much as possible but I guess my brain just doent do the whole cam thing. I have no idea how to selection the proper duration and lfit and things of this nature. so help please?
The stunningman
02-10-2007, 09:00 AM
For mild builds such as this the 274 extreme by comp cams is almost always a good choice.
LS69TA
02-10-2007, 09:59 AM
If you've got the RPM air-gap intake, the Performer RPM cam isn't a bad cam. I've ran it before and it wasn't bad at all. I had a 2400 stall in my 70 C10 with a 350. It's a 308/318 duration (232/242 @ .050 I think) with .488/.510 lift 1500-6500rpm. I'm going to put the same one in my boat next week.
Teh Wicked
02-10-2007, 11:57 AM
What kind of Idle are we looking at on those cams mentioned? Rough, or is it smooth? I prefer a very notceable idle but I dont want a all out drag race cam that you have to pedal the motor just to get it to idle.
Is this the cam your referring too?
http://www.sdpc2000.com/catalog/1976/products/120217/XE274H-1800-6000-RPM-SB-Chevrolet-Hydraulic-Flat-Tappet-Xtreme-Energy-Camshaft-Kit.htm
Is this the cam you are referring too?
http://www.sdpc2000.com/catalog/780/products/6752/SB-Chevrolet-Performer-RPM-Camshaft-Kit.htm
LS69TA
02-10-2007, 01:13 PM
Yea, that's the one I was talking about. You can tell that there is a cam in the motor, but it's not enough that you have to worry about driving it.
The stunningman
02-10-2007, 08:36 PM
yep. Thats the cam I was recomending.
1997bird
02-10-2007, 10:56 PM
Why so big of carb? What model is it?
My01SSCamaro
02-11-2007, 02:23 AM
carb alittle big i think. i would stay around 480-490 lift and around the 230ish duration and 110 lsa thats your ganna be your best bet its ganna have a decent lope and wont have any power brake problems heres a vid of my 355 build its got brodix aluminum heads 750 demon air gap intake with cc 507-510 lift 240-246 duration and 110 lsa with 1.6 to 1 rockers is 540-544 lift
http://s123.photobucket.com/albums/o291/my01sscamaro/?action=view¤t=MOV01953.flv
Teh Wicked
02-11-2007, 07:44 AM
Cool, THink I may hold off on the Carb, Apparently according to my lil bro the truck already has a Eldlebrock already sitting on top of it. so it looks like I will just stick with the heads, intake and cam for now.
Now what is the differance bewteen a hydraulic roller and a flat tappet cam? I know a solid roller cam is pretty much a race car cam and not very streetable. im still just trying to figure out the cam process here.
http://s123.photobucket.com/albums/...nt=MOV01953.flv
You referring to something like this?
http://store.summitracing.com/partdetail.asp?part=CCA%2DSK12%2D676%2D4&autoview=sku
